Just out of curiosity, how did you install Grass 6.0? I would think that you
would also need superuser privileges to install 6.0.
~ Eric.
-----Original Message-----
To: grassuser@grass.itc.it
Sent: 7/11/2006 4:44 AM
Subject: [GRASS-user] Can't start GRASS 6.0.0
Hello, as a new user... I guess I am getting the common problems... I
intalled GRASS 6.0 because were I work I cannot intall 6.1 ( I cannot
unzip
the files of the 6.1) as I am not the complete administrator of my
computer.
I started to try with the shearfish data and when I try to ENTER GRASS
it
does not start... I get the following error:
GRASS 6.0.0 (shearfish60):~>Error un start up script : child process
exited
abno rmally when executing ...
I tried several times and I also tried to start it by using the command
"d.m
& ", a screen (with a detail of a map) shows up Loading data, it says
Done
but I get the same error again...
Can anyone advice me what to do? Thanks
María Piquer
_________________________________________________________________
Un amor, una aventura, compañía para un viaje. Regístrate gratis en MSN
Amor
& Amistad. http://match.msn.es/match/mt.cfm?pg=channel&tcid=162349
grassuser mailing list
Hello,
When installing GRASS for Windows with cygwin , at the step select your internet connection: as Direct connection (as especified in the point 2 of the manual http://geni.ath.cx/grass.html#toc6) I get the error: Can't get the list of download sites. Make sure your network settings are correct and try again.
Can anyone explain me what to do now...? should I select another internet connection?
Thanks, thanks, thanks
MarÃa
To: 'MarÃa Piquer RodrÃguez ' <almecloud@hotmail.com>, "'grassuser@grass.itc.it '" <grassuser@grass.itc.it>
Subject: RE: [GRASS-user] Can't start GRASS 6.0.0
Date: Tue, 11 Jul 2006 10:58:23 -0300
~ Eric.
unzip
computer.
it
exited
"d.m
Done
MarÃa Piquer
Un amor, una aventura, compañÃa para un viaje. RegÃstrate gratis en MSN
Amor
Un amor, una aventura, compañÃa para un viaje. RegÃstrate gratis en MSN Amor & Amistad. http://match.msn.es/match/mt.cfm?pg=channel&tcid=162349
Hello Maria,
Instead of installing from the internet directly , i installed it from a CD. Found it more convinient.
First i downloaded the .iso image file and then burnt it on a CD.
Given below is the link for downloading the .iso image file (~500MB) for installing cygwin GRASS
https://www.geographie.uni-freiburg.de/~mlechner/CygwinGRASS/CygwinGRASS-0.4.iso
This single image file when burnt onto a CD, forms the following files and folders on it:
autorun.inf ,//setup.exe,// grass.ico, oldCygwinGRASS-0.2.1_install.pdf,
repository, //, Handbücher.//
On loading the CD on CDROM drive, the installation process should start automatically.
With the help of CygwinGRASS-0.2.2_install.pdf manual i carried out the installation./
Regards
Nagesh
María Piquer Rodríguez wrote:
Hello,
María
To: 'María Piquer Rodríguez ' <almecloud@hotmail.com>, "'grassuser@grass.itc.it '" <grassuser@grass.itc.it>
~ Eric.
unzip
computer.
it
exited
"d.m
Done
María Piquer
Amor
Un amor, una aventura, compañía para un viaje. Regístrate gratis en MSN Amor & Amistad. http://match.msn.es/match/mt.cfm?pg=channel&tcid=162349
Hi Nagesh and Maria,
As "producer" of the CygwinGRASS-Image I just have to point out, that it is based on a GRASS-CVS-Version from Spring 2005 (but it
works well - just doesn't inlude all the features developed since then)
Marco
Von: grassuser-bounces@grass.itc.it
[mailto:grassuser-bounces@grass.itc.it] Im Auftrag von Nagesh Bhatkar
Gesendet: Mittwoch, 12. Juli 2006 12:06
An: María Piquer Rodríguez
Cc: grassuser@grass.itc.it
Betreff: Re: [GRASS-user] Can't start GRASS 6.0.0
Hello Maria,
ygwinGRASS-0.4.iso
oldCygwinGRASS-0.2.1_install.pdf, repository, //,
Handbücher.// On loading the CD on CDROM drive, the
the installation./
Regards
Nagesh
> Hello,
especified in the
> María
>> From: "Patton, Eric" <epatton@nrcan.gc.ca>
would think
>> that you would also need superuser privileges to install 6.0.
>> ~ Eric.
>> From: grassuser-bounces@grass.itc.it
problems... I
( I cannot
>> unzip the files of the 6.1) as I am not the complete
administrator of
>> my computer.
>> GRASS it does not start... I get the following error:
child process
>> exited abno rmally when executing ...
>> command "d.m & ", a screen (with a detail of a map) shows
up Loading
>> data, it says Done but I get the same error again...
>> María Piquer
gratis en
>> MSN Amor & Amistad.
> MSN Amor & Amistad.
