This looks like an excellent addition to the Grass FAQ at the grass website. Any chance you could put something there?
Jerry
---- Original message ----
Date: Wed, 11 Jul 2007 08:04:53 +0200 (CEST)
Subject: RE: [GRASS-user] importing .dgn files in grass
To: grassuser <grassuser@grass.itc.it>--- nishith datta <nkdiitd2002@gmail.com> escribió:
hi all
I have been able to import a dgn file into grass
using the v.in.ogr but I
have all the point, line and poly
features in the same layer. Next When i use v.what
then I get a attribute
listing which I can't quite understand
Anyone who can help me out with - how to seperate
the point , lines and
polys into three different layers. Also
if possible there could be different things
represented as lines - roads and
rivers both are line features. So how to extract
these from the .dgn file
into two different layers. I am attaching the output
of v.what command for
ease of anyone who wishes to help me out.
Output of Grass v.what command :-East: -21786.9555969
North: -23164.1739966
Map: nkd
Mapset: PERMANENT
PointLayer: 1
Category: 9362
driver: dbf
database:
/ramdisk/grass/locations/43p/PERMANENT/dbf/
table: nkd
key column: cat
cat : 9362
Type : 17
Level : 3
GraphicGro : 0
ColorIndex : 0
Weight : 1
Style : 0
EntityNum :
MSLink :
Text : PaswalWhen I try to see the layers in the .dgn file using
the option list
available layers in the dataset and exit from
v.in.ogr
I get the output
Data source contains 1 layers:
elementsBut I think the data source contains more than one
layer - atleast one line,
one point and one poly for sure. What is the meaning
of the above
output.....Thanks in advance.
NishithGRASS Layer, is not the same of dgn's Layer(Level)
Make a external database conection:
v.external dsn=yourmap.dgn output=yourmap
open yourmap in a monitor
You can test every entity in the dgn with v.what
Make attention on the Level value, and others fields
values of the entities you want to include in a vector
GRASS file.Import just this entities with the the option
"where=":v.in.ogr -z -o dsn=yourmap.dgn output=yourmapX
where=Level=X min_area=0.0001 snap=-1And so on for each map
Juan M. Garijo
______________________________________________
LLama Gratis a cualquier PC del Mundo.
Llamadas a fijos y móviles desde 1 céntimo por minuto.
http://es.voice.yahoo.com_______________________________________________
grassuser mailing list
Gerald Nelson
Professor, Dept. of Agricultural and Consumer Economics
University of Illinois, Urbana-Champaign
office: 217-333-6465
cell: 217-390-7888
315 Mumford Hall
1301 W. Gregory
Urbana, IL 61801
