RE: [GRASS-user] ogr2ogr and r to vect
Thank you very much, this is something I will pursue as this project gets
more on its feet.
Currently my difficulty with ogr2ogr is where to put the file to be
re-projected, so the program knows where to find it. It looks from the
examples that it should be in root, and the program run at command line and
not through GRASS? My initial inclination was to set the .shp file in the
main location folder outside of the mapsets and run via the GRASS command
prompt, though as I look further in to the OGR documentation it seems there
are other ways to do so, but no directions on where to put the .shp (SSURGO)
file.
I have started with a new location which should display the ortho photos
with d.rgb, but does not in GRASS, though it will in QGIS in the location,
using the GRASS tools to open the current region, in Debian - odd, I am
still looking at the data for a clue, the projection is consistent as is the
location.
As to smoothing the 'steps,'
I recently came across references to improving the analysis of raster data
by expanding the analysis capabilities to work with the cell data, by
re-thinking the centroid (I think an 'R' related article I was looking at) -
I could not find the exact reference again, but maybe the 'TURKU' project
libral raster algebra library could be of help in smoothing steps -
http://sourceforge.net/project/showfiles.php?group_id=123937&package_id=1358
33&release_id=399025
Thank you for the r to vect assistances, I look forward to working that up.
:slight_smile: Daniel
-----Original Message-----
[mailto:grassuser-bounces@grass.itc.it]On Behalf Of Dylan Beaudette
Sent: Monday, January 08, 2007 1:25 PM
To: grassuser@grass.itc.it
Cc: carlos.grohmann@gmail.com
Subject: Re: [GRASS-user] ogr2ogr and ortho/rgb display
On Monday 08 January 2007 12:29, Maciej Sieczka wrote:
Carlos "Guâno" Grohmann wrote:
>> Please note that reprojecting a floating point grid will usually yield
>> "stairs" distortion in the output, depending on how big is the skew
>> between the input and output projection. That's propably what Dylan
>> meant. The "stairs" distortion will be the bigger, the less smoothing
>> involved in the reprojection.
> Maciek,
> are you aware of any publication that explain this kind of distortion?
No.
Maciek
" Necessity is the mother of invention " ... sounds like a fine time to
write
this up!
I am actually in the process of doing this type of analysis for another
project if anyone is interested in collaborating.
Dylan
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
grassuser mailing list
I've been away from GRASS for a while and just loaded 6.2. [Hey, at least I didn't have to bug anyone this time to do the compilation.] The menus have changed enough that the tutorial doesn't match anymore. I've googled to look for an up to date tutorial without luck. Does it exist?
Gary
Hello gary,
Not that I know of. I was thinking about an update a while ago, but
this plan was lowerd in priority due to important project work.
If you feel willing to help on updating the tutorial, raise your hand.
We appreciate any help on this.
Best regards
  Stephan
Stephan Holl : www.intevation.de/~stephan | GISpatcher:
www.gispatcher.de Intevation GmbH: www.intevation.de | GAV
e.V.: www.grass-verein.de Georgstr.4 : 49074 Osnabrück |
Telefon: +49(0)541. 3350832
Gary
AFAIK not yet. It would be great, if someone would take the tutorial
from Otto Dassau http://gdf-hannover.de/media.php
There is some subversion repository around.
Thanks
Jachym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://www.les-ejk.cz/pgp/jachym_cepicky-gpg.pub
OFFICE:
Department of Geoinformation Technologies
Zemedelska 3
613 00, Brno
Czech Republick
e-mail: xcepicky@node.mendelu.cz
URL: http://mapserver.mendelu.cz
Tel.: +420 545 134 514
On Wed, 10 Jan 2007 12:41:10 +0100
Jachym Cepicky <jachym.cepicky@centrum.cz> wrote:
> Gary
The tutorial was written by Stephan Holl and Markus Neteler as well ;-),
and the english version of the latex sources can be found here:
https://subversion.gdf-hannover.de:8080/websvn/listing.php?repname=GRASS+6+Tutorial+-+Translation+Portal&path=%2Ftrunk%2Fenglish%2F&rev=0&sc=0
The text is released under GNU FDL, but it might be a good idea to contact GDF
Hannover (info@gdf-hannover.de) first, if you are interested to take that
tutorial and update it for GRASS. I would appreciate that.
regards,
Otto
Thanks
Jachym
Is there a way I can download all the files?
I am working on a tutorial, but it is in portuguese...
Carlos
              Carlos Henrique Grohmann - Guano
  Geologist M.Sc - Doctorate Student at IGc-USP - Brazil
Linux User #89721 - carlos dot grohmann at gmail dot com
_________________
"Good morning, doctors. I have taken the liberty of removing Windows
95 from my hard drive."
--The winning entry in a "What were HAL's first words" contest judged
by 2001: A SPACE ODYSSEY creator Arthur C. Clarke
On Wed, 10 Jan 2007 13:01:22 -0200
you can checkout the svn tree:
svn checkout
https://subversion.gdf-hannover.de:8080/svn/translations/trunk/english
Otto
Carlos
Tell you what. I'll copy the tutorial to my hard drive and tweak it with NVU as I find changes. [Since I got such great help running CVA from this list, it is the least I can do.] However, somebody who knows what they are doing should check out my changes.
Stephan Holl wrote:
Hello gary,
Best regards
  Stephan
