That's odd, then. Glynn mentioned that LFS hadn't been implemented in
r.in.xyz (yesterday). The data I was working with had positive z values
instead of negative (it's bathymetry), so I tried using awk on my z column,
but awk choked on the file as well. So I seem to be running into OS system
limits, maybe? I split the file into three chunks, and r.in.xyz/awk ran
smoothly from there on.
~ Eric.
-----Original Message-----
To: Patton, Eric
Cc: GRASS Users
Sent: 10/19/2006 7:58 PM
Subject: Re: [GRASS-user] r.in.xyz: Could open text file ~ 2.5GB
Eric,
Have you tried running an identical command on a small sub sample of
your data?
Personally, I haven't had any LFS support problems with r.in.xyz.
This included scanning a text file for extents as your trying to do.
After the initial thread was started with respect to r.in.xyz's LFS I
went back and checked some of the test data sets that I have. They're
all beyond the 2GB limit (3.7GB is the largest i've tested so far)
and I haven't had any problems with the program. As far as I can see,
the only thing I have noticed that is different with a file beyond
the 2 gig size is that the progress indicator never comes up. I think
most people can live with that. I have a 500 million point dataset
that I'm trying to get out of las binary format right now. When
that's done I'll pass that through r.in.xyz and report how that goes.
I figure it'll be around 15GB in size, so if that doesn't trip up
r.in.xyz then I don't think anything will.
Mike
On 19-Oct-06, at 11:19 AM, Patton, Eric wrote:
I'm trying to open a text file to scan for extents:
r.in.xyz -s input=2006MB_GarryTrough_1N.txt
output=2006MB_GarryTrough_1N
method=mean type=FCELL fs=space x=1 y=2 z=3 percent=100Could not open input file
</home/epatton/Projects/Whalen/PERMANENT/WORK/
2006MB_GarryTrough_1N.txt>.I get the same error regardless of what percent parameter is set to
(60, 40,
10). Is this an LFS problem with r.in.xyz?~ Eric.
grassuser mailing list
grassuser@grass.itc.it
__________________________________________________
Do You Yahoo!?
Tired of spam? Yahoo! Mail has the best spam protection around
http://mail.yahoo.com
