RE: [GRASS-user] r.in.xyz: Could open text file ~ 2.5GB
Glynn,
I applied your patch in the root of my source code folder (/opt/grass6)
using this command:
patch -p0 < r.in.xyz_LFS_patch
then 'make' within grass6/raster/r.in.xyz, and make install from grass6.
Is that command sequence correct? I'm unfamiliar with patching. If so, I'm
still receiving the same error when r.in.xyz tries to open my input file:
r.in.xyz -s input=GarryTrough_1N_2006.txt output=test fs=space
ERROR: Could not open input file <GarryTrough_1N_2006.txt>.
Could my OS be imposing some sort of file size limit despite LFS in
r.in.xyz? I'm using Ubuntu 6.06 on a 32-bit PC.
~ Eric.
-----Original Message-----
To: Patton, Eric
Cc: 'grassuser@grass.itc.it'
Sent: 10/19/2006 2:01 PM
Subject: Re: [GRASS-user] r.in.xyz: Could open text file ~ 2.5GB
Yes. r.in.xyz won't accept input files >2GiB on a 32-bit system (one
where the C "long" type is 32 bits), regardless of whether or not
GRASS was built with --enable-largefile.
The attached patch might be sufficient, although the progress
percentage will be wrong (it will reach 100% at 2GiB rather than at
the end of the file).
<<r.in.xyz LFS patch>>
using this command:
Yes; but see below.
Although, rather than running "make install", you can run the
newly-built version in-place by running the grass63 script in the
bin.<arch> directory, e.g.:
  /opt/grass6/bin.i686-pc-linux-gnu/grass63
If so, I'm
I forgot that the --enable-largefile switch only enables LFS in
libgis, not anywhere else.
[Although config.h includes definitions to enable LFS automatically,
those definitions are currently inactive. This is probably a good
thing; a lot of GRASS' code isn't LFS-aware, and explicit failure is
preferable to silently corrupting data.]
To enable LFS elsewhere, you need to manually add
-D_FILE_OFFSET_BITS=64 to the compilation flags. The simplest approach
is to add:
ifneq ($(USE_LARGEFILES),)
  EXTRA_CFLAGS = -D_FILE_OFFSET_BITS=64
endif
to raster/r.in.xyz/Makefile, then repeat the "make" and "make install"
steps.
