RE: [GRASS-user] Use of r.watershed
Thanks. I will try and change my threshold value this evening.
A little background, I have completed this phase of the project at "work" using ArcHydro and it took about half a day total to run through the tools (fill, flow direction, flow accumulation, etc.). I am trying to now do the same project at home using open source tools as a means of learning grass and as a comparison. I wonder if the r.watershed algorithms differ enough from the ArcHydro ones to make execution times very different? Any thoughts?
Quoting Charles Ehlschlaeger <c.ehlschlaeger@insightbb.com>:
r.watershed will take a long time for a 8,600x10,300 cell DEM under any
circumstance. Your threshold value (400) might also be slowing things down.
How large should your smallest exterior watershed basin be? If your grid
cells are 10mx10m, your basins will be 400x10mx10m = 40,000 m^2: not that
large. The larger the th value, the faster the program will run.
Sincerely, chuck
Chuck Ehlschlaeger, Geospatial Science Consultant
PERTAN GROUP, http://pertan.com/
c.ehlschlaeger@insightbb.com, 309-255-2727
http://chuck.ehlschlaeger.info/
-----Original Message-----
[mailto:grass-user-bounces@lists.osgeo.org] On Behalf Of
hydro@hydromodeling.com
Sent: Wednesday, January 23, 2008 8:52 AM
To: Charles Ehlschlaeger
Cc: grass-user@lists.osgeo.org
Subject: RE: [GRASS-user] Use of r.watershed
Chuck,
Thanks for your reply. The DEM has 8,627 rows and 10,270 columns.
The command line statement I used is:
r.watershed el=fill th=400 ac=fac ba=basins st=str
I have also tried using the -m and -4 flags placed after the r.watershed
part.
Matt
How many rows and columns are in the input map? Also include the exact
command line statement you use to run the program.
Sincerely, chuck
Sent: Wednesday, January 23, 2008 7:15 AM
To: grass-user@lists.osgeo.org
Subject: [GRASS-user] Use of r.watershed
Hello All,
I am new to GRASS but have been using GIS (mainly ESRI products) for
quite a few years. I am trying to learn how to use GRASS to carry out
hydrology related analyses. Currently, I am trying to use the
r.watershed command to delineate the basins for a watershed. My
question is, how long would you expect it to take to run? I am
wondering if I am doing it wrong or if it just takes longer than I
would expect. The DEM is about 170MB TIFF before I import it to
GRASS. I have tried to run it a few times using different options,
each time letting it run for 3 - 4 hours before killing it. I have
tried both the -m and -4 flags. Any input would be appreciated.
grass-user mailing list
No virus found in this incoming message.
Checked by AVG Free Edition.
Version: 7.5.516 / Virus Database: 269.19.9/1238 - Release Date: 1/22/2008
8:12 PM
No virus found in this outgoing message.
8:12 PM
8:12 PM
8:12 PM
If you are in a relatively flat area, there needs to be consideration given to the algorithm (to my knowledge there is no “choice” in the ArcGIS suite) used to do the most important thing: delineate the watershed basin. Since the question was asked about differences, this may apply if your terrain is relatively flat.
From the r.watershed manual, “If watershed divides contain flat to low slope, r.watershed will generate better basin results than r.terraflow. (r.terraflow uses the same type of algorithm as ESRI’s ArcGIS watershed software which fails under these conditions.)” http://download.osgeo.org/grass/grass63/manuals/html63_user/r.watershed.html
Mark
“work” using ArcHydro and it took about half a day total to run
Sincerely, chuck
[mailto: grass-user-bounces@lists.osgeo.org] On Behalf Of
Chuck,
part.
Matt
Sincerely, chuck
Hello All,
8:12 PM
8:12 PM
8:12 PM
8:12 PM
Thanks for pointing out the excerpt from the manual. So, based on that it seems that r.watershed will take longer to run than the ArcHydro tools. How much longer? I guess I will just let it run and see if I can find out. Then I will run r.terraflow and compare the differences between ArcHydro, r.terrafow and r.watershed.
If anyone has used r.watershed on a comparably sized DEM, I would be interested to hear how long it took to run. By the way my machine has a 2.8Ghz P4 processor and 1.25G of RAM.
Quoting M S <mseibel@gmail.com>:
to the algorithm (to my knowledge there is no "choice" in the ArcGIS suite)
relatively flat.
From the r.watershed manual, "If watershed divides contain flat to low
slope, *r.watershed* will generate better basin results than *r.terraflow*.
(*r.terraflow* uses the same type of algorithm as ESRI's ArcGIS watershed
software which fails under these conditions.)"
Mark
down.
that
> Sincerely, chuck
> From: grass-user-bounces@lists.osgeo.org
> Chuck,
> part.
> Thanks,
> Matt
>> Sincerely, chuck
>> Hello All,
>> _______________________________________________
1/22/2008
>> 8:12 PM
1/22/2008
>> 8:12 PM
1/22/2008
> 8:12 PM
1/22/2008
> 8:12 PM
Here is a small comparison I did a while back on watershed delineation,
comparing r.watershed, r.terraflow, and basin from Arc/Info:
http://casoilresource.lawr.ucdavis.edu/drupal/node/284
note that it is a little sparse on the details, and could use some better
figures. see code examples for explanation.
cheers,
Dylan
> given to the algorithm (to my knowledge there is no "choice" in the
> *r.terraflow*. (*r.terraflow* uses the same type of algorithm as ESRI's
> ArcGIS watershed software which fails under these conditions.)"
>tml
> Mark
>> > any circumstance. Your threshold value (400) might also be slowing
>> > things
>> down.
>> > grid cells are 10mx10m, your basins will be 400x10mx10m = 40,000 m^2:
>> > not
>> that
>> > Sincerely, chuck
>> > Chuck,
>> > r.watershed part.
>> > Thanks,
>> > Matt
>> >> exact command line statement you use to run the program.
>> >> Sincerely, chuck
>> >> Hello All,
>> >> out hydrology related analyses. Currently, I am trying to use the
>> 1/22/2008
>> >> 8:12 PM
>> 1/22/2008
>> >> 8:12 PM
>> 1/22/2008
>> > 8:12 PM
>> 1/22/2008
>> > 8:12 PM
Dylan Beaudette
Soil Resource Laboratory
University of California at Davis
530.754.7341
see also here for some comparison:
http://www.cs.duke.edu/geo*/terraflow/speedup.html
> r.watershed part.
On modern systems using -m will slow it down a lot for minor memory
savings. Don't use it. I wouldn't bother with -4 either.
r.terraflow
note as far as output basins go this calculates something different-
sink-watersheds not catchment watersheds. see
  http://thread.gmane.org/gmane.comp.gis.grass.user/21564/focus=21579
But r.terraflow should run in minutes.
Yes I have run on something that size, and bigger. It could take up to
two days to complete, but it gets there with nice results. I usually
set it up to run on a friday afternoon and it's done by the time I get
back on monday. Setting the process priority low (ie high renice value)
helps if you leave it running during the week.
To get started, you might try the examples given for the Spearfish
dataset in the help page and on the wiki,
  (help page home is in transition- broken link right now)
  http://grass.gdf-hannover.de/wiki/Psmap_flooding_example
Hamish
      ____________________________________________________________________________________
Be a better friend, newshound, and
know-it-all with Yahoo! Mobile. Try it now. http://mobile.yahoo.com/;_ylt=Ahu06i62sR8HDtDypao8Wcj9tAcJ
Markus:
it doesn't list GRASS version but from the Pentium III and March 2001
references I would expect that the version of r.watershed there was
from GRASS 5.0 and using the old color setting code which proved to be
a terrible bottleneck. The r.watershed in newer versions of GRASS can
be much much faster.
Hamish
Never miss a thing. Make Yahoo your home page.
http://www.yahoo.com/r/hs
