Hi Glynn,
The g.parser usage is <filename> [<argument> ...]
For it to be changed the logic would be to loop through the arguments
until a non-file name occurs. Logic would have to be added to see if
any arguments remain. If this is acceptable design, I can add the code.
John Huddleston
-----Original Message-----
From: Glynn Clements [mailto:glynn.clements@virgin.net]
Sent: Monday, December 01, 2003 12:38 PM
To: Request Tracker
Cc: grass5@grass.itc.it%INTER2
Subject: Re: [GRASS5] [bug #2238] (grass) r.series: support for wildcards in
input filenames
Importance: Low
Request Tracker wrote:
It would be nice if r.series would accept wildcards for the input maps.
e.g.
r.series input=insitu_data.* output=insitu_data.stddev method=stddevfor:
insitu_data.001
insitu_data.002
insitu_data.052
That may also true for several other modules; in which case, it might be
better to figure out how to build this into G_parser().
such as the g.mremove script does. [0-9] expansions etc would be nice too,
but not critical.
g.mremove is a shell script, which makes implementing shell substitutions
somewhat easier.
glibc has the glob() function, which is apparently specified by POSIX.2,
although I would be reluctant to just rely upon its existence (e.g. it might
not be present on all platforms, or it may require an additional library).
For now I use a bash loop to set INPUT_MAPS=$INPUT_MAPS,next_map then
'r.series input=$INPUT_MAPS ...', but that sort of sucks.Any reason not to activate this module for 5.3 yet?
Only the standard reason: once a module becomes "official", changing its
behaviour becomes problematic.
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
