RE: [GRASS5] configuration/build failure on solaris 8, curses and get/putwc
I had the same problem with curses. I fixed it by ignoring warnings.
Set the following before running configure:
   setenv CPPFLAGS -w
Also, make sure that GNU make and tar are found first:
   setenv PATH /usr/local/bin:$PATH
Bev Wallace
Lockheed Martin in Sunnyvale, CA, USA
(408) 756-0494
beverly.t.wallace@lmco.com
-----Original Message-----
Sent: Tuesday, June 18, 2002 10:27 AM
To: grass5@grass.itc.it
Subject: [GRASS5] configuration/build failure on solaris 8, curses
and get/putwc
The subject line refers to the cause of the problem, not just my
reaction to it. I believe the problem is nested includes from
"curses" redefining getwc/putwc. This is on Solaris 8 (Sparc) with
gcc 2.8. My results reported are from the current CVS build, but my
results with pre4 were similar.
"configure" with the current release tree, and with pre4, fails with
the following error:
checking for remove... yes
checking for shmat... yes
checking for IceConnectionNumber in -lICE... yes
checking for curses.h... no
configure: error: *** Unable to locate curses includes.
However, I think the problem surfaces higher up, where "configure" reports
checking how to run the C preprocessor... gcc -E
checking for ANSI C header files... yes
checking for limits.h... yes
The log file segment for the initial curses.h check looks like this:
configure:2319: checking for curses.h
configure:2327: gcc -E conftest.c >/dev/null 2>conftest.out
In file included from /usr/include/curses.h:23,
                  from
/usr/local/lib/gcc-lib/sparc-sun-solaris2.8/2.95.2/include
/curses.h:5,
                  from configure:2323:
/usr/include/widec.h:38: warning: `getwc' redefined
/usr/include/iso/wchar_iso.h:337: warning: this is the location of the
previous
definition
/usr/include/widec.h:39: warning: `putwc' redefined
/usr/include/iso/wchar_iso.h:340: warning: this is the location of the
previous
definition
/usr/include/widec.h:40: warning: `getwchar' redefined
/usr/include/iso/wchar_iso.h:338: warning: this is the location of the
previous
definition
/usr/include/widec.h:41: warning: `putwchar' redefined
/usr/include/iso/wchar_iso.h:341: warning: this is the location of the
previous
definition
configure: failed program was:
#line 2322 "configure"
#include "confdefs.h"
#include <curses.h>
configure:2319: checking for limits.h
and the final segment of the log file looks like this:
configure:3629: gcc -o conftest -g -O2 -L/usr/openwin/lib
conftest.c -lICE -lsocket -lnsl 1>&5
configure:3669: checking for curses.h
configure:3677: gcc -E conftest.c >/dev/null 2>conftest.out
                  from
/usr/local/lib/gcc-lib/sparc-sun-solaris2.8/2.95.2/include/curses.h:5,
                  from configure:3673:
the previous definition
#line 3672 "configure"
#include <curses.h>
Hal Mueller hal@mobilegeographics.com
Mobile Geographics LLC http://www.mobilegeographics.com/
Seattle, Washington (206) 297-9575
MapTap public test now underway!
http://www.mobilegeographics.com/maptap/
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
