Bev and all,
On Mon, May 14, 2001 at 12:13:10PM -0700, Wallace, Beverly T wrote:
Markus and all,
I noticed that g.manual was there twice too.
Sorry from here, it was an undeleted binary residual.
In fact we have the script version active now and the C code present, but
unused. Should be removed when g.manual script is working everywhere.
On a Solaris 5.6 machine, the
script is the one that is used, and it does not work.
I get an "awk" error from the script version of g.manual. I was able to fix
that, but then there was another syntax problem with an "if" statement. I
fixed that, but there were still more problems, so I gave up. There are
probably even more syntax problems with statements that I did not reach.
"awk" problem:
awk -F '='
Solaris fix:
awk -F=
"if" problem:
[ -e $html -a "$GRASS_TEXT_BROWSER" ]
Solaris fix:
[ "-e $html" -a "-e $GRASS_TEXT_BROWSER" ]
Thanks for this hint! I got it working on solaris, but
- didn't need your awk modification
- quotes another if statement
Here the diff to "old" CVS version:
cvs diff g.manual
Index: g.manual
RCS file: /grassrepository/grass/src/scripts/contrib/g.manual/g.manual,v
retrieving revision 1.20
diff -r1.20 g.manual
171c171
< if [ -e $html -a "$GRASS_TEXT_BROWSER" ]
if [ "-e $html" -a "$GRASS_TEXT_BROWSER" ]
178c178
< elif [ -e $man -a ! "$GRASS_TEXT_BROWSER" ]
elif [ "-e $man" -a ! "$GRASS_TEXT_BROWSER" ]
After fixing this, g.manual runs well for Linux and Solaris2.6.
I have updated in CVS.
Please report if any other platform is causing problems (after update).
cvs up src/scripts/contrib/g.manual
gmake5 -i src/scripts/contrib
which g.manual # be sure to use the script version
g.manual d.rast
> -----Original Message-----
> From: Markus Neteler [SMTP:neteler@geog.uni-hannover.de]
> Sent: Sunday, May 13, 2001 3:06 AM
> To: grass5 developers list
> Subject: [GRASS5] g.manual twice
> Hi all,
> we have currently g.manual twice in GRASS
> - src/general/g.manual
> - scripts/contrib/g.manual
> As far as I remember, the script is new. Shall I remove the
> old C-implementation?
> At time (due to path order) the C version will be used.
> Markus
> If you want to unsubscribe from GRASS Development Team mailing list write
> to:
> minordomo@geog.uni-hannover.de with
> subject 'unsubscribe grass5'
Markus Neteler * University of Hannover
Institute of Physical Geography and Landscape Ecology
Schneiderberg 50 * D-30167 Hannover * Germany
Tel: ++49-(0)511-762-4494 Fax: -3984
