RE: [GRASS5] GRASS 5.1 v.in.ascii bug
Here's another example of different warnings on different boxes:
In my chunk of test code I include stdio.h because I thought that
was all I needed. gcc with -Wall on sun, no warnings.
gcc with -Wall on Redhat 7.3 with gcc 2.96:
warning: implicit declaration of function `exit'
You need stdlib.h to define exit.
With the talk recently of cflow, I discovered lclint.
Does anyone recommend that? It seems to go overboard
with "recomendations".
How do you enable -Wall with gmake5?
Or do you just compile manually?
int get_tiger_record (FILE *fp, char type, char *buffer){
<snip>
register int c,j
<snip>
while ( c=getc(fp) ){
   if (c == (int) type){ /* original code did not have */
      buffer[0] = (char)c; /* these type cast. */
The above compiles fine with no warnings but without the cast
lclint mentions that c is int and (buffer, type) are char.
The cast eliminate the lclint warnings BUT this looks like
exactly the thing Glynn was warning about concerning casting.
Do I leave out the (int) and (char) cast as in the original code?
I think int and char are ALWAYS 1 byte. Correct?
(This is again from the now famous v.in.tig.basic code.)
John
