[Re: [GRASS5] GRASS in Windows95/98]
    I figured out part of my problem in opening grass is that I have to
configure it and I have not gotten the configuration program to work properly
yet..
   As far as the rast.to.vect command I may have the command incorrect, but
what I am attempting to do is to convert images of architectural drawings of
an archaeological site that are at this moment in Tiffs into vecter dxf files.
I am certain that this was done in GRASS when I did it as a student. I hope it
wasn't in another program such as Idrisi or such.
Thanks
Brad
"John Huddleston" <jhudd@lamar.colostate.edu> wrote:
Since XGrass was removed you do not need X11R6.4.
Are there Fortran components in Grass? I can't remember
off hand. If you develop then yes, otherwise no.
Help me out with the rast.to.vect command. I cannot find
this in the Grass5 source. What command are you looking
for?
John
----- Original Message -----
To: <grass5@geog.uni-hannover.de>
Sent: Sunday, July 30, 2000 1:05 AM
Subject: [GRASS5] GRASS in Windows95/98
    Do I still need all the other bits such as g77 and X11R6.4 to get GRASS
to
work or all I need is the preconfigured downloads?
   For the moment all I need is to get the rast.to.vect to work. Though I
would like to get a DEM going, but without a monitor it may not be much
use.
   yours
   Bradley Harrison
John Huddleston <jhudd@lamar.colostate.edu> wrote:
> hi Bradley,
> Many of the grass data manipulation functions
> are available for windows. The monitor (or
> display) is not yet available. I have not tried
> the Tcl/Tk interface yet though.
> You will have to install either the older Cygwin
> B20.1 distribution or the newer version 1.1.2
> in order to get the "unix" commands and DLLs
> required to run grass under Windows.
> The ZIP distribution looks for executables under the
> /usr/local/grass-5.0b area. Forward slashes only make
> sense when using Cygwin.
> John Huddleston
> If you want to unsubscribe from GRASS Development Team mailing list write
to:
> minordomo@geog.uni-hannover.de with
> subject 'unsubscribe grass5'
____________________________________________________________________
Get free email and a permanent address at http://www.netaddress.com/?N=1
to:
Brad,
One of the things that Cygnus does not do for you
is set up the /bin connections. So, you have two
choices, use a symbolic link or use a mount.
Please tell me which system you are using and I can
help you better. Do a `cygcheck -v -s -r` and email
the output to me.
To do a link to wherever the Cygwin bin is installed.
first execute a bash shell, and do the
`ln -s /Cygwin/bin /bin`
To do it as a mount point, run a CMD window and
mkdir c:\bin, and run the command
`mount -b c:\Cygwin\bin /bin`
The configure and make system will now work.
Both commands above assume that you are using
Cygwin 1.1.2 and installed it under C:\Cygwin.
If you are using 95/98 I recommend upgrading
to NT or 2000. The video display drivers are
much better.
John Huddleston
To: John Huddleston <jhudd@lamar.colostate.edu>;
Sent: Tuesday, August 01, 2000 5:41 AM
Subject: Re: [Re: [GRASS5] GRASS in Windows95/98]
properly
yet..
files.
it
Thanks
Brad
for?
John
to
use.
   yours
   Bradley Harrison
> hi Bradley,
> John Huddleston
write
to:
to:
to:
