Thanks for replying my mail....
I have an Alpha DS10 running Redhat Linux (kernel 2.2.14-14) and...
compiler is 'gcc (egcs-1.1.2)'.
Your help would be greatly appreciated!
Thanks!
----- Original Message -----
To: <grass5@geog.uni-hannover.de>
Sent: Friday, June 16, 2000 2:56 PM
Subject: Re: [GRASS5] Help:how to run 3d_module on alpha(compaq ds-10)
On Fri, Jun 16, 2000 at 01:22:34PM +0900, wrote:
> I'm a student studying the Grass.. but,
> d.3d module doesn't run with spearfish database on the
alphaserver(compaq ds10).
> The error message is followed:
> 'Floating point exception'
> and exit module.
> I think that the module doesn't run because spearfish data is not
64-bit.
> Tell me how to run 3d module ....
I have the resources to fix this, I just haven't explored it yet.
I work for Compaq and I have an Alpha running Debian Linux, and another
running Compaq Tru64 UNIX. Which operating system were you using on the
DS10 to generate this error? Which compiler?I need to spend a few moments starting up a cvs checkout, as soon as I
find where the CVS server is and what the anon login is.--
James Cameron mailto:quozl@us.netrek.org http://quozl.netrek.org/----------------------------------------
If you want to unsubscribe from GRASS Development Team mailing list write
to:
subject 'unsubscribe grass5'每每每每每每每每每每每每每每每每每每每每每每每每每每每每每每!眉篓禄搂露脷.聻脣聸卤脢芒m莽毛垄a聭$聝z梅楼垄聶聻聻脭脼ji職聤X搂聜X卢路
芒碌毛h镁h搂垄路h職聫脿z聢每潞x每聟漏莽垄梅芦媒脳掳聤脴l鹿赂脼r脽卯聻脣聸卤脢芒m猫+j脣9
