[Re: [GRASS5] ISO C90 does not support `long long']
On Wed, 2006-02-01 at 10:13 +0100, Markus Neteler wrote:
using the "-pedantic" gcc flag, I get this message:
include/grass/dgl/type.h:66: warning: ISO C90 does not support `long long'
How to fix that line?
It's a pitfall of C90 - any integer type larger than long is not
supported. FYI, this also spells doom for large file support, too.
What minimal coding standards does GRASS conform to? ANSI C (C89-C90)?
Unless there is a quick workaround, is there any reason for not
supporting C99?
By the looks of the vector library, it'll be difficult to fix because
they are fed to read()/write(). Perhaps it could be poorly fixed by
reading and writing two ints and splitting it into upper and lower
dwords.
My $0.02 (and falling)
Glynn?
Brad Douglas <rez@touchofmadness.com> KB8UYR
Address: 37.49,-121.92 / WGS84 National Map Corps #TNMC-3785
GRASS GIS Developer
supporting C99?
It isn't a question of "supporting" C99, it's a question of
"requiring" C99.
We shouldn't require anything other than C89 except where necessary
(e.g. system interfaces).
