RE: [GRASS5] Library Issues
Much of this is relics from the old digitizing and air photo routines.
Some
date back as far as FHIS if memory serves me correctly. It's hard code
for specific (and non-exsistant anymore) devices. Most of this can I
think
safely go away, but there are some global calls that should remain. I
remember this from hacking up r.nntool. I will try and dig up my notes
on what is/was junk.
Bruce
  -----Original Message-----
  Sent: Fri 4/12/2002 5:45 AM
  To: grass5@grass.itc.it
  Cc:
  Subject: [GRASS5] Library Issues
  I've been analysing the interdependencies between the various
  libraries, and wished to discuss some of the results.
  1. The following symbols are referenced in libimage_sup.a, but
don't
  appear to be defined anywhere:
          symbol |object
          mark_control |photo_init.o
          Menu_msg |ltm_anal.o
          Menu_msg |photo_anal.o
          Menu_msg |poly_anal.o
          read_elev |ltm_anal.o
          read_elev |ltm_trans.o
          read_elev |photo_anal.o
          read_elev |photo_trans.o
          select_current_env |convert_ll.o
          select_target_env |convert_ll.o
  Can anyone shed any light on this? Are they meant to be defined
by the
  application? If so, the interface should probably be changed to
use an
  explicit callback.
  There are also a number of undefined symbols in libgeo.a:
          D_ask_driver_raw
          D_clear_driver
          D_cursor_buttons
          D_foot_switch
          D_get_scale
          D_read_raw
          D_setup_driver
          D_setup_origin
          D_start_button
  It appears that these are meant to be provided by a "driver"
(although
  the only implementation which I can find is
src.contrib/OTHER/numonics).
  Is this the case?
  2. A significant number of global symbols are defined in
multiple
  libraries; in particular, the following are defined in both
libortho.a
  and libimage_sup.a:
          I_ask_camera_any
          I_ask_camera_new
          I_ask_camera_old
          I_compute_ortho_equations
          I_find_camera
          I_find_initial
          I_get_con_points
          I_get_group_camera
          I_get_group_elev
          I_get_ref_points
          I_inverse_ortho_ref
          I_list_cameras
          I_new_con_point
          I_new_ref_point
          I_ortho_ref
          I_put_con_points
          I_put_group_camera
          I_put_group_elev
          I_put_ref_points
          I_read_con_points
          I_read_ref_points
          I_write_con_points
          I_write_ref_points
  The following symbols are also multiply defined:
          symbol |object |library
          Bugs2 |error.o |libimage_sup.a
          Bugs2 |error.o |libortho.a
          I_georef |georef.o |libI.a
          I_georef |georef.o |libortho.a
          inverse |m_inverse.o |libortho.a
          inverse |inverse.o |libtrans.a
          isnull |isnull.o |libortho.a
          isnull |inverse.o |libtrans.a
          m_add |matrix_ops.o |libimage_sup.a
          m_add |m_add.o |libortho.a
          matrix_error|ref_ortho.o |libimage_sup.a
          matrix_error|orthoref.o |libortho.a
          m_copy |matrix_ops.o |libimage_sup.a
          m_copy |m_copy.o |libortho.a
          m_mult |matrix_ops.o |libimage_sup.a
          m_mult |m_mult.o |libortho.a
          m_mult |m_mult.o |libtrans.a
          transpose |jacobi.o |libgmath.a
          transpose |m_transpose.o|libortho.a
  Can someone who is familiar with the imagery code look into the
  apparent duplication, and whether it can be eliminated?
  The matrix stuff will ultimately be handled by the gmath
library.
  3. There are three pairs of libraries which are mutually
dependent:
          im_lib |ex_lib
          libgis.a |libcoorcnv.a
          libstubs.a |libdbmi.a
          libvect.a |libdig2.a
  a)
          libgis.a references:
          CC_datum_name
          CC_datum_shift
          CC_get_datum_by_name
          libcoorcnv.a references:
          G_realloc
          G_fatal_error
          G_warning
          G_ellipsoid_name
          G_get_ellipsoid_by_name
          G_get_spheroid_by_name
          G_getl
          G_gisbase
          G_store
          G_strcasecmp
          G_strcat
          G_strcpy
          G_strip
  The obvious solution is to move coorcnv/datum.c into libgis.
  b)
          libstubs.a references:
          db_procedure_not_implemented
          libdbmi.a references:
          db_driver_add_column
          db_driver_bind_update
          db_driver_close_cursor
          db_driver_close_database
          db_driver_create_database
          db_driver_create_index
          db_driver_create_table
          db_driver_delete
          db_driver_delete_database
          db_driver_describe_table
          db_driver_drop_column
          db_driver_drop_index
          db_driver_drop_table
          db_driver_execute_immediate
          db_driver_fetch
          db_driver_find_database
          db_driver_finish
          db_driver_init
          db_driver_insert
          db_driver_list_databases
          db_driver_list_indexes
          db_driver_list_tables
          db_driver_open_database
          db_driver_open_insert_cursor
          db_driver_open_select_cursor
          db_driver_open_update_cursor
          db_driver_update
  I haven't looked very far into this, but libdbmi probably needs
to be
  split into two separate libraries; a high-level library above
the
  drivers, which provides the API to clients, and a low-level
library
  which provides utilities for the drivers.
  c)
          libvect.a references:
          dig_alloc_points
          dig_bound_box2
          dig__fill_head_portable
          dig__fread_port_C
          dig__fread_port_D
          dig__fread_port_I
          dig__fread_port_L
          dig__fwrite_port_C
          dig__fwrite_port_D
          dig__fwrite_port_I
          dig__fwrite_port_L
          dig__Init_portable_code
          dig_load_plus
          dig_new_to_old_type
          dig_old_to_new_type
          dig_point_in_poly
          dig__set_cur_in_head
          dig__set_cur_out_head
          dig_struct_copy
          dig_x_Rd_P_area
          dig_x_Rd_P_att
          dig_x_Rd_P_isle
          dig_x_Rd_P_line
          dig_x_Rd_Plus_head
          dig_x_Rd_P_node
          dig_x_Wr_P_area
          dig_x_Wr_P_att
          dig_x_Wr_P_isle
          dig_x_Wr_P_line
          dig_x_Wr_Plus_head
          dig_x_Wr_P_node
          libdig2.a references:
          dig_Rd_P_area
          dig_Rd_P_att
          dig_Rd_P_isle
          dig_Rd_P_line
          dig_Rd_Plus_head
          dig_Rd_P_node
          dig_Wr_P_area
          dig_Wr_P_att
          dig_Wr_P_isle
          dig_Wr_P_line
          dig_Wr_Plus_head
          dig_Wr_P_node
          V2_read_line
  What is the distiction between libvect.a and libdig2.a? Should
they be
  combined? Or is all of this going to be replaced in 5.1?
  grass5 mailing list
  grass5@grass.itc.it
  http://grass.itc.it/mailman/listinfo/grass5
