GRASS5 is compiled, and appears to run, but are there any sample data
sets I can use to test and familiarize myself with GRASS5?
Yes there are. Please download the Spearfish data from the GRASS main site.
This is standard to begin with.
You may also take other data and create them yourself.
********** Output from testgrass.sh **********
org:/install/grass5.0.0pre3 # ./testgrass.sh
testing in UTM projection environment:
projection: 1 (UTM)
zone: 13
datum: ** unknown (default: WGS84) **
ellipsoid: ** unknown (default: WGS84) **
north: 4928000
south: 4914000
west: 590000
east: 609000
nsres: 50
ewres: 50
rows: 280
cols: 380
Test the -129 r.mapcalc bug:
EXECUTING testmap = ... 100%
CREATING SUPPORT FILES FOR testmap
range: -129 -129
r.mapcalc bug test o.k.
Tests finished.
My goal is to display county level data sets, currently in FIPS codes,
onto a map of the US, and individual states. I'd like to deliver the
images via webserver to clients using a browser.
This is what program called 'grasslinks' handles; I have a working site
at http://tigers.ru/webgrass_e
As I perused the
programming manual, I noticed that there are limitations to html's ability to
render clickable points, which I can work through later,
I can't quite understand to that point. You want to click a point in browser
and read associated info?
but I'd like
to know if I'm on the right track in using GIS & GRASS5.
Absolutely.
Also, any
links, hints or info anyone can provide to additional information would be
greatly appreciated.
Have you looked at http://grass.itc.it (links, infos, htmls,...)?
--alex
