Helena,
The kind of parallelization (by subregion) you are talking below can be
easily achieved by [ab]using my pd-GRASS module. pd-GRASS uses shell
scripts and ssh to distribute GRASS on a cluster. Each node gets its
own subregion. pd.run will run any GRASS command in parallel on the
cluster nodes thus each regions will be processed on a separate node.
The only function that is missing in pd-GRASS is to assemble results
into a single map. Everything else is pretty much taken care of by
pd-GRASS.
Alex Sorokine, Ph.D. <sorokina@ornl.gov>
Oak Ridge National Lab
-----Original Message-----
[mailto:grass5-admin@grass.itc.it] On Behalf Of Helena Mitasova
Sent: Friday, November 25, 2005 2:38 PM
To: Muzaffer Ayvaz
Cc: grass5@grass.itc.it
Subject: Re: [GRASS5] Parallel GRASS modules for high performance[...skip...]
The problem with these implementations is that unless the
developer is committed to keeping them up to date they die
pretty quickly (e.g. the rst works with GRASS5 but not GRASS6).
So I have been begging everybody who tries to do parallel
stuff for grass to do the parallelization on top of the
modules rather than within the modules so that they are
minimally dependent on changes within the modules. For
example, v.surf.rst can be run efficiently by splitting
region into smaller overlapping subregions and sending each
subregion to a different processor and then patch the results
together. Same can be done for r.mapcalc , r.slope.aspect and
many other modules (there are some exceptions such as modules
that include flow routing). This may have its own problems
but it is definitely more general and has much better chance
of surviving beyond one release cycle than writing a parallel
version of a module.[...skip...]
