RE: [GRASS5] Problem compiling Grass51
make mixclean
cvs update -d -P
make mix
Pardon my ignorance. Let me make sure I understand how to maintain
my 5.1 version.
make mixclean = deletes the links back to grass CVS version.
cvs update -d -P = updates to current version, but this may fail if
                   the links are still present.
make mix = redo links to grass CVS version.
make
Is this basically correct?
Additional question: I assume to keep the cvs version and 5.1
synced you want to:
cvs update -d -P (in cvs version)
make
to make the cvs version current BEFORE you do the above to the
5.1 version?
I assume I have the terminology correct. There are 3 versions:
release (5.0.2)
cvs (5.0.2 with bug fixes, changed frequently)
5.1 (changed almost daily)
Correct?
John
John,
I have added an UPDATE section to the INSTALL file of 5.1.
Please update
cvs up INSTALL
and check if it is clear now (suggestion welcome).
Yes.
release (5.0.2)
Correct?
Right (the 5.0.x release version is not important for 5.1).
Maybe better:
[release_5.0.2]
cvs_head_5.0.x
cvs_head_5.1
