Hi Radim,
I am running bin.$(ARCH)/grass51.
It finds the GRASS shared libraries if I move "export LD_LIBRARY_PATH"
outside of the if statement in etc/Init.sh as you suggested.
if [ ! "$LD_LIBRARY_PATH" ] ; then
LD_LIBRARY_PATH=$GISBASE/lib
else
LD_LIBRARY_PATH=$LD_LIBRARY_PATH:$GISBASE/lib
fi
For Solaris, it works OK if LD_LIBRARY_PATH starts with a colon, but
I don't know about other systems.
Thank you,
Bev
-----Original Message-----
Sent: Thursday, September 18, 2003 12:37 AM
To: grass5@grass.itc.it
Subject: Re: [GRASS5] Solaris GRASS 5.1, shared libraries, external PROJOn Wednesday 17 September 2003 23:28, Wallace, Beverly T wrote:
> Dear GRASS Developers,
> I have at last successfully built GRASS 5.1 (2003_09_06) on Solaris 9.
> Thank you to everyone who gave me advice.
> The ps/ps.map/Makefile needs Proj includes:
> EXTRA_INC = $(VECT_INC) $(PROJINC)OK, done in cvs.
> In order to run grass51, I needed to set LD_LIBRARY_PATH to find the shared
> libraries in dist.$ARCH/lib and the external PROJ.4 lib. This was not
> mentioned in the INSTALL file.This is done in etc/Init.sh:
else
fithis section is identical to 5.0, but why it is exported only
in the first case, would not be betterif [ ! "$LD_LIBRARY_PATH" ] ; then
else
fiexport LD_LIBRARY_PATH
and is it necessary to test if $LD_LIBRARY_PATH is defined,
is it ':/some/path' error?Maybe you are not running GRASS within regular session?
BTW, you can run applications without $GISRC and user mapset.
(example in GRASS++ and QGIS)Radim
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
