RE: [GRASS5] TINs as 3D vectors
There is no possibility of creating 3D-vectors from v.delaunay directly.
We are currently implementing a system for vague regions in GRASS that
uses triangulations with 3D vectors, and have linked Triangle to GRASS.
Triangle is a much faster and memory efficient delaunay triangulation
with support for constraints. See
http://www-2.cs.cmu.edu/~quake/triangle.html for more information.
As soon as everything is done we'll release a few useful GRASS modules,
including this better Delaunay triangulation and the 2D alpha-shape
algorithm, and perhaps some 2D visualization of TINs which might be
useful as a general module with some slight modifications. If you need
it now I can send you the module.
Pieter Bos
-----Original Message-----
From: grass5-admin@grass.itc.it [mailto:grass5-admin@grass.itc.it] On
Behalf Of Jachym Cepicky
Sent: Wednesday, April 13, 2005 2:10 PM
To: GRASS Developers list
Subject: [GRASS5] TINs as 3D vectors
Hallo,
is there any possibilty, how to create 3D-vector of TIN (triangulated
irregular network) of the output from v.delauny? I have 3D points and
v.delauny makes only 2D-polygons from it..
I wrote some script which solves this, but before I post it, I would
like to know, that I did not something useless.
Thank you a lot
Jachym
Jachym Cepicky
e-mail: jachym.cepicky@centrum.cz
URL: http://les-ejk.cz
GPG: http://www.fle.czu.cz/~jachym/gnupg_public_key/
Triangle does not appear to have a clear license compatible with GPL:
"Please note that although Triangle is freely available, it is copyrighted by the author and may not be sold or included in commercial products without a license."
Am I wrong? If you want to include that to GRASS distribution, the library must have a license which gives at least the same rights as GPL.
Do you have a module for conversion from raster to TIN?
How do you store the data, do you use your format? Did you try to use GRASS format?
Radim
Pieter Bos
Hallo,
Thank you a lot
Jachym
Jachym Cepicky
grass5 mailing list
grass5@grass.itc.it
http://grass.itc.it/mailman/listinfo/grass5
