This is good information to know. I have been looking at vector
processing modules also and have wondered if I was "wasting"
my time by not looking at 5.1. My concern is that what I do
for 5.0 will change with 5.1. These comments make it clear to me
that I need to compile 5.1 and start looking at what's different.
In particular, I have been looking in v.digit and v.build at
topology building and checking routines to see how lower level
routines can be used to build higher level functions.
I'd also like to document what I figure out. The programming
manual has little information at this level of internals.
It would be good if we can coordinate our work. Or at least share
what areas we are working in. (I'm thinking specifically
of the vector area.)
John
-----Original Message-----
From: Helena Mitasova [mailto:hmitaso@unity.ncsu.edu]
Sent: Monday, February 24, 2003 10:16 AM
To: cheg01@attbi.com
Cc: grass5@grass.itc.it
Subject: Re: [GRASS5] v.digit color name mismatchcheg01@attbi.com wrote:
>----- Original Message -----
>From: "Radim Blazek" <blazek@itc.it>
>To: <cheg01@attbi.com>; <grass5@grass.itc.it>
>Sent: Monday, February 24, 2003 12:53 AM
>>Hi Chris,
>>I see that you are working on v.digit, I would like to only note
>>that work on v.digit in 5.1 was also started:
>>http://mpa.itc.it/radim/g51/v.digit3.png
>>Radim
>I suspect that 5.0 will continue to have a large user base
for some years
>to come. Is there an expeced release date for 5.1?
Chris, if you are doing anything with vector modules I are greatly
encourage you to look at 5.1
and coordinate your work with Radim. The vector capabilities
in 5.0 are
not adequate
and we all need to work on getting 5.0 merged with 5.1 as soon as
possible so that we can have a working version
of GRASS5.1 with everything in it - I expect that people will
switch to
GRASS5.1 as soon as it becomes
usable because of its vector and database support, so I would not put
much effort in fixing 5.0 vector stuff.
This is just my view, others may see it differently.Helena
>_______________________________________________
>grass5 mailing list
>grass5@grass.itc.it
>http://grass.itc.it/mailman/listinfo/grass5
grass5 mailing list
grass5@grass.itc.it
