RE: [GRASS5] very confused over NULL in rasters
I'll ponder these suggestions more. I think you may have
solved part of the problem.
Bill B.
-----Original Message-----
Sent: Sunday, December 17, 2000 3:20 PM
To: 'grass5@geog.uni-hannover.de'
Subject: Re: [GRASS5] very confused over NULL in rasters
On Sun, Dec 17, 2000 at 11:42:45AM -0700, William L. Baker wrote:
Unfortunately, I cannot simply use the library functions.
r.le reads in the whole raster and works with it internally,
deciding what values constitute a "patch" and then
tracing the boundaries of it etc.
I still think it's possible.
Life would be simpler if GRASS had library functions
to do all the things that are needed to make r.le work!
Maybe you could outline what those things are. If they would be
generally useful, we could consider them for library function additions
in 5.1.
So, I need to know the actual representation of null in
the raster itself and in the null-value file from bringing it
in with G_get_null_value_row.
If you read the raster the "normal" way, G_open_cell_old(), the "proper"
NULL value will be embedded in the rows that are subsequently read. You
can obtain a copy of the NULL value for the raster type using
G_set_null_value(rast, 1, maptype) which you can use for subsequent
comparisons; where rast is a void * to the proper number of bytes for
one cell based on cell type (4,4, or 8 generally).
So, for a CELL map, you get INT_MAX embedded. For FP, you get the
appropriate NaN.
Since I don't know the specifics, of r.le.xxxx, maybe I'm missing
something here as to what you need...
Eric G. Miller <egm2@jps.net>
If you want to unsubscribe from GRASS Development Team mailing list write
to:
subject 'unsubscribe grass5'
