Barry,
We have an HP 730 that is running GRASS 4.0. We had virtually no problem with
the installation. You need to specify where the XDRIVER libraries are. I
love the speed of the HP. We were running on a MASSCOMP prior to this. We also
support the Altek Digitizer and a TEK4697 inkjet on the HP.I would highly recommend the HP.
Many thanks. One good recommendation like this is probably all that was
needed anymore to finalize the hardware choice. From the incoming mail
list, I suspect yours will not be the only recommendation, either!
I'm glad I came across this mail group.
Tim.
