So far am I knowing of Helena's work from UNIBA they are even using about
5-7 labels (original and derivated parameters) for 1 site... a standard
format should allow more than one label per site if needed...F. Hoffmann
Now I see this, I agree that this is also not such a bad idea. Then the
s.programs will just need some way of addressing the required attribute field,
($1, $2, ... etc? - an "awk-like" solution to the weak site-database
capabilities of GRASS.)
Simon
___________________________________________________
__ L Dr Simon Cox
,~' L_|\ VIEPS Department of Earth Sciences,
,-' \ Monash University, Clayton Vic 3168
( \ Australia
\ ___ / Phone +61 3 905 5762
L,~' "\_x/ Fax +61 3 905 5062
u simon@artemis.earth.monash.edu.au
