Re:MAPGEN install
Alejandro Hinojosa writes:
and the following is the error message:
<proj>:
projection initialization failure
cause: no system list, errno: 2
program abnomally terminated
</im/grass/mapgen/bin/mapdef>: invalid header
Do you know how can i fix it. Thanks in advance :slight_smile:
The problem is that the variable PROJ_LIB is not defined. This variable
should point to a resource file called proj_def.dat under $GISBASE/etc.
Be sure to check for the resource file. If it's not under the $GISBASE/etc
directory, it can be found under scr at PROJ.4.3.0/nad/proj_def.dat
Define the following:
setenv PROJ_LIB $GISBASE/etc
or
PROJ_LIB=$GISBASE/etc
This should take care of the problem.
Jill
# # #### #### #### ###### #### ##### Jill R. Schuler
# # # # # # # # # # USDA
# # #### # # #### ### #### # #### Soil Conservation Service
# # # # # # # # # # National Cartography and
# # # # # # # # # # GIS Center
#### #### #### # # #### ###### #### P.O. Box 6567
                    Ft. Worth, TX 76115
e-mail: jschuler@ncg.scs.ag.gov Phone: (817) 334-5559 x3086
