RE : need help (MSS, raw file import)
Group: info.grass.user, Item 8239 (Range: #8239 - #8272, Unread: 5)
Subject: need help
From: pubu@gfi.uib.no (Pu Bu Ci Ren), University of Illinois at Urbana
Date: 2 Apr 96 09:05:24 +0100
reading data in other place, transfer it to my hard disk, then I use small
program which is written by me to extract each band file from the big image
file on hard disk, the data format is 8 bit binary file, I use XV to
display it, it is successful.
When I use grass, I created a location and mapsheet for mss data, I input the
column and row number( 3600, 2286), then move all four band files to directory
cell under mapsheet MSS, then I try to use d.rast to display it, I got message
: can't open rast file ...
Did you create the header file (in cellhd) ?
If not, try just using r.support.
                        Hope this helps.
        | Pascal GOUERY : Tel.: 99.14.13.47 |
        | C.R.I. : 99.14.13.52 |
        | Universite de Rennes 2 : Fax.: 99.14.13.50 |
        | 6, Av G.Berger : |
        | 35043 RENNES CEDEX : e.mail: Pascal.Gouery@Uhb.Fr |
        | FRANCE : |
