RE: New GIS.sh (GRASS modules access problem)
Hi Alan, Luis, Venkatesh (?) and GRASS with bash shell users,
we seems to have two different problems using bash and GRASS:
1: When using bash shell, the GRASS modules cannot be accessed.
   The solution is an updated (from yesterday) GRASS-script "GIS.sh",
   which supports bash. The original script only supports c-shell
   and tc-shell (sch, tcsh). I added a bash section, which works
   fine:
   You find the latest version on
     Bereich Geographie – Naturwissenschaftliche Fakultät – Leibniz Universität Hannover
   Make a savety copy of your original GIS.sh (which stays in grass4x/etc)
   and copy this new file into that directory.
   The script will add the GRASS path settings to your standard paths
   during the GRASS session.
   If this script updated fixes the path problems everywhere, we shall
   replace it in GRASS source code package and binary packages.
2: Some users reported a problem opening a GRASS monitor due to permission
   problems. This is new at least to me as I am also user of Suse 5.3/bash
   /GRASS 4.2.1.
   In my opinion this problem is not related to above path problems.
   Possible ways to check this permission situation are:
   - /usr/local/grass4x/locks must get rwx permissions (read,write,execute,
     change with chmod ugo+rwx locks/) for everybody (I think there is no
     security problem as standard /tmp has same permissions)
   - there must be a subdirectory inside this locks/ named as your machine
     (check that with uname -n). Take care of caps letters.
   - this subdirectory also needs rwx permissions for everybody
   If this does not help, please write again...
   I am using the same system, but did not need any "tricks".
   So I expect the *second* problem to exist due to local permission
   problems. The *first* path problem should be fixed through the updated
   GIS.sh script.
Good luck
PS: If anyone has a different opinion concerning the permission settings,
    please let me know. All comments are welcome.
There may be a third problem, but it may be pathologically related to the
first two: Even when accessing a new mapset, I haven't been prompted for
location information---I haven't seen that screen that asked for coordinates
for the corners.
I still haven't implemented all the fixes yet, though.
Alan Davis
Alan E. Davis Marianas High School (Science Department)
AAA196, Box 10001 adavis@netpci.com http://www.saipan.netpci.com/~adavis
Saipan, MP 96950 15.16oN 145.7oE GMT+10 Northern Mariana Islands
I think you will find that you left out the t found in the very last
column of the permissions in /tmp directories:
  drwxrwxrwt 17 root root 4096 Jan 27 09:31 /tmp/
These are the recomended permissions for a 'world' accessable
directory.
  chmod 1777 /tmp
or
  chmod 1777 locks
as the case may be, is probably the easiest way to ensure that exactly
the correct bits are set on such a directory.
Nicolai
