Its worth understanding the role that feature Types have across
different OGC specs - they are poorly integrated in the current round > ofOGC specs but this may improve.
image shows how common data base serves a common feature expressed
through several interfaces and operations: WFS, SLD and GetFeatureInfoSo, following from this reality, as well as the fact that FeatureTypes
will increasingly be externally defined, IMHO the GeoTools >architecture
needs refactoring to allow common configuration around the >FeatureTypes,not the database connections.
I completely agree with this!!! For me there're really two level of
configuration: one at the DataStore level, that is only the connection
params or whatever needed to reach the data. This info may be configured by
whatever existing mechanism (like GeoServer or uDig ones or using the Spring
framework).
Then there's the real important info, the one about FeatureTypes. That info
should be in a catalog implemented inside GeoTools and usable by any project
using GeoTools (like GeoServer and uDig). The way this info is persisted is
irrilevant (even if we don't see any good reason why it shouldn't be
accessible through DataStores), its it's semantic that needs to be shared
and agreed upon.
For each FeatureType we must be able to know such things as structure,
validation and security (at a minimum) and this BEFORE to connect to any
DataStore. That is, the structure of a FetureType must exists even before
it's implementation inside a DataStore, otherwise how do you call a
createSchema()???
Also a FetureType may be abstract, so that it's not actually implemented by
any DataStore, but there may be other concrete FeatureTypes inheriting from
it, so that you could make a query upon the abstract one and get results
from all it's descendants.
Or you can have a concrete FetureType that's implemented by several
different DataStores, and you may choose one of them in a mirroring style,
or you can make the union of them all.
Gabriel Roldan is doing some design work around these issues at the
moment, so if there is going to be some work done elsewhere can we try
to keep the activities in sync so we can schedule a single refactoring.Rob Atkinson
We're not actually refactoring anything, but we created a simple Meta engine
that let's one define things about FeatureTypes. You can find it here:
http://www.geotools.org/Meta+Information+Infrastructure
I'm sorry it's not updated, but the core of it is not changed. I'm also
sorry because it lacks a good demo, but there's a pretty extensive
description. Also you may look the comments inside the core class:
it.ama_mi.sis.framework.meta.MetaSpace
Bye
Paolo Rizzi
Jody Garnett wrote:
Including a lot of your email dave because it is subject matter for
the OpenSDI mailing list.I haven't put a lot of thought into the new 2.0 "Geo Application
Framework" so I don't really know where - exactly - its going. But,
I
though I'd throw a few ideas out so people can put their 2 cents in
too...There's been a bit of trend to not put components in Geotools, which
I
hope is turning around. At least everyone is talking about
re-merging.
Catalog is something that really needs to be stuck back in geotools
as
almost everyone doing non-trivial projects needs one. Paolo already
mentioned some ideas on this, and I know that Jody, Chris and I have
also mentioned it.First of all a word of encouragement:
- Setting up a Framework is important - it is the one thing uDig
development has taught us A good framework makes all the
difference.
- You are not as far away from 2.0 as you think, GeoServer is already
broken into chunks. The WFS and WMS talk to an interface called Data.
They don't have to see the same Data implementation. BTW Data ==
Catalog == Configuration of data connections.
- Catalog (or Data) implementations: GeoServer GlobalData, Geotools
Repository, uDig ICatalog - these are all the same class/idea.Basically GeoServer is already organized in the right manner, what is
lacking is a consistent framework to drop the components into.
And provide persistence, configuration, web ui for configuration,
channeling of requests (regardless of XML/KVP) etc...If I was doing this I would:
- scrounge up the framework chunks (based on some research, such as
occurs of the OpenSDI list)
- implement the easiest service possible; Feature Portrayal Service
because it does not have any data
- release for public abuse of the framework components
- port the uDig Catalog (and merge with GeoServer Data)
- port the GeoServer WFS
- release for public abuse (and assistence in passing Cite tests)
- port the GeoServer WMS, WCS and so on
- release for public abuse as a betaNote this allows the framework to have a logical progression of
capabilities for the request/response subsystem.
- GET (w/ KVP) and Image (non XML) response for FPS
- POST (w/ XML request) and XML Response first (for WFS)
- SOAP / WSDL later (for service chaining)Note I would expect the system to be *easy*. Drop a module in, with
required request response schemas. And a discoverable class for
prossing of the same.
Indeed you can probably handle the KVP get requests just using
reflection as long as the parameters are sufficiently well known.
public Image WMS.getMap( Envelope bbox, List<Layer> layers, int width,
int height ) for example
In generic terms, I think the new architecture will look something
like
this (Jody and Chris have already talked about this):
1. The "Core GeoServer" will be quite small, and basically serve as
the
container for other services and handle such tasks like:
* taking requests and routing them to the correct plugin
service
* manage the Dataset catalog
* manage configuration (often being passed off to the service
plugins)
* Anything else we think is a "common good" that will
make building and managing services easier2. WFS/WMS/WCS will be example services that people could either
download-and-plugin or would come as separate downloads.
Each of the plugins would be responsible for handling the actual
requests, and any service-specific configuration. The plugins would
use the framework core to help implement the actual services. They
would also be responsible for all their configuration (including the
web-app to actually do the config).This differs from the "GeoCollaborator" system which isn't really
supposed to be smart and build new services up from scratch - its
supposed to enhance existing services. Geoserver 2.0 is supposed to
make it a easier to develop and deploy new services.I'm not sure exactly what this will look at - this is something we
really need to spend time and hammer out. There's lots of
pros-and-cons
of putting different services (or service-helpers) in the core or
making the sub-components completely responsible for them. And
example
would be security and user authentication; where (exactly) should it
be
managed - there's lots of different places to put it.
(Feel free to reply with better suggestions and comments)
Personally, I think this is a pretty ambitious task thats going to
take
quite a bit of time to actually pull-off. This is especially so if
we
try to actually implement these things inside geotools instead of
having complete control inside geoserver. The unfortunate situation
is
that, certainly from a web-configuration perspective, geoserver maybe
at variable stages of "unuseable" during the lengthy transition.(As an aside, I believe jody and his team spent a lot of time on just
the STRUTs web app for config - see jody's message on this.)I think you can see that the two biggest things to change will be (1)
the catalog stuff and (2) the config stuff.I keep repeating myself, but for people doing things like the
ingestion
engine need to just be warned that things will be changing in the
future so make sure that you make the program easy-to-change. I don't
think there's going to be any radical changes (we're still going to
have datastores and feature-type, etc...), but how its organized and
the actual content could change significantly. I expect you folks to
be involved in all these decisions so its not something thats going
to
sneak up on you.
There's been a bunch of good suggestions floating around from
everyone
in this conversation.
I did like paolo's idea of using Features to represent configuration
information (like the catalog and security) so you can leverage
existing geotools infrastructure like datastore (persistence) and
filter (searching).Alessio, also, had a bunch of good idea in his email messages.
I would steer away from this, there are existing technologies for
configuration and security that
we should be using. Lets use them and save our energies for the actual
work we need to do in
making a OWS framework.-------------------------------------------------
In a more practical manner, I don't really know what the timeframe
that
these major changes will take place. I think it will really depend
on
what you folks want to do.
I'm a bit risk-adverse on the issue since I want to ensure that
Geoserver is always getting better - easier to configure and more
stable. This might require a 1.3 branch and a radically different
2.0
branch, which can be a maintenance problem.
I talked to jody about moving some of the Udig work out of udig and
into
geotools, and I'm not sure what his plan is for it. I dont think it
was
something planned over the short time; and I've heard estimates from
2
weeks to 1 year.
It is more that unless there is a project (or developers) that need
this functionality in geotools
there is no advantage to backporting. The estimate is more based on
when will another project
be interested in working together then any technical difficulty.But if there is interest it can be done, there is not that much code
and it is of high quality. Right now there
is more interest in backporting a lot of the uDig rendering
goodness...
Dave
Jody
SF.Net email is sponsored by: Discover Easy Linux Migration Strategies
from IBM. Find simple to follow Roadmaps, straightforward articles,
informative Webcasts and more! Get everything you need to get up to
speed, fast. http://ads.osdn.com/?ad_id=7477&alloc_id=16492&op=click
Geoserver-devel mailing list
<<WMSWFSrelationship.gif>> <<ATT07151.txt>>
