I cannot reproduce the FTP error some of you are describing using any of
our local machines, even PC's. Thus I would like to request the following
information from anyone experiencing FTP problems.
I have tried from two very different systems here with identical results.
One is a Sun Sparcstation 4 running SunOS 4.1.1, and the other is
a DECstation 3100 running Ultrix 4.2. A log of a session from the
Ultrix machine follows-- note the "-" password used to turn off the
advanced features made no difference in the problem. This session
shows the intermittent nature of the problem, as the dir command works
sometimes, but fails mostly, at seemingly random intervals.
Connected to max.cecer.army.mil.
220 max.cecer.army.mil FTP server (Version 6.20 Thu May 28 11:53:13 CDT 1992) ready.
user
ftp> (username) anonymous
331 Guest login ok, send e-mail address as password.
230 Guest login ok, access restrictions apply.
ftp> dir
200 PORT command successful.
425 Can't build data connection: Interrupted system service.
ftp> dir
ftp> dir
ftp> dir
ftp> dir
ftp> dir
150 Opening ASCII mode data connection for /bsd43/bin/ls.
total 15
dr-x--x--x 2 root root 512 Apr 24 09:26 bin
dr-x--x--x 3 root root 512 Apr 15 10:33 bsd43
dr-x--x--x 3 root root 512 Apr 22 09:51 etc
lrwxrwxrwx 1 root root 1 Apr 22 09:51 ftp -> .
drwxrwxr-x 10 root 110 512 Sep 14 11:19 grass
dr-x--x--x 2 root root 8192 Apr 15 09:50 lost+found
drwxrwxr-x 2 root localftp 512 May 29 11:20 pub
drwxr-xr-x 2 root other 512 Aug 18 16:12 pyr
226 Transfer complete.
498 bytes received in 0.078 seconds (6.2 Kbytes/s)
ftp> dir
ftp> dir
cd grass
ftp> 250 CWD command successful.
ftp> dir
ftp> dir
ftp> dir
total 13
-rw-rw-r-- 1 140 110 249 Sep 17 11:07 .message
-rw-rw-r-- 1 140 110 3111 Sep 17 11:12 README
drwxrwxr-x 2 140 110 512 Sep 17 11:29 ftpHelp
drwxrwxr-x 3 140 110 512 Aug 24 15:38 grass3.0
drwxrwxr-x 7 140 110 512 Sep 11 16:08 grass4.0
drwxrwxr-x 10 140 110 512 Sep 17 09:56 grass4.1
drwxrwxr-x 2 140 110 512 Sep 17 11:29 grassHopper
drwxrwxr-x 5 140 110 512 Sep 17 10:52 grassInfoCenter
drwxrwxrwx 5 140 110 1024 Sep 17 12:28 incoming
drwxrwxr-x 7 140 110 512 Sep 17 11:00 otherPrograms
662 bytes received in 0.39 seconds (1.7 Kbytes/s)
ftp> dir
ftp> 200 PORT command successful.
ftp> bye
221 Goodbye.
Jim Aanstoos
Research Triangle Institute
email: aanstoos%gizmo@rti.rti.org
or jva@rti.rti.org
