Date sent: 3-APR-1992 07:43:15
I want to run grass4.0 on a remote machine (orion) and have my
machine (wadif) serve as the host.
So first on wadif I said:
xhost orion
Then on orion I said:
rlogin wadif
setenv DISPLAY orion:0
Here you should run another program like xterm or xclock just to be
sure you can open a display. It looks like your doing everything ok
as far as the display goes though.
Then I bring up grass on orion.
It says:
MAPSET: gary (this is the user name for orion)
DATABASE: ../grass.dataThen upon entering grass it says:
Sorry no access to <<gary>>
Mapsets in location <spearfish>
PERMANENT gary root
note: you do not have access to any of these mapsets.I checked these mapsets and all of the permissions are turned on.
Any ideas? Thanks.
I have a guess that your not getting your enviornment variables setup
correctly. So check your .login and or .profile and or .cshrc for
conditional statements changing things if your loging in remotely.
You can manually execute these files for your current session using
the source command i.e. source .login
Hope this helps,
Gerry Hatcher
Ocean Mapping Development Center| Gerry@omdc.gso.uri.edu {Internet}
University of Rhode Island |
(401)-792-6940 | cbeam::gerry {span}
