Hello again,
Thanks to all with the advice on d.mon and SG3d. I got SG3d running all right
(and love it...), but I still have problems with d.mon and the IRIS driver, and
though I have spent many hours on it, cannot run xgdisplay at all.
* Try to run Display Tool (from menu):
-it appears for a split second, then disappears, so...
-open GRASS shell, and message box, apparently for Display Tool appears
"XGRASS DISPLAY LIB ERROR: Not enough colors available. Make more avail
able before starting again."
-I don't quite know what to do about that.
The machine is an IRIS Indigo, and has lots of color normally...?
* Using IRIS display driver:
-I've uncommented the one iris line in the monitorcap file, and it
appears below -- with just "iris", no "i0,i1,i2,...,i6" and I don't
see how I can just add them, since iris refers to fifo.11a and fifo.11
b
whereas "x0, .... x7" refer to several sets of fifo.* pairs. Do I hav
e
the fifo.* for the i0 through i6?
-I added "iris" and "CELL" to the d.mon text file in the XCLIP dir. Now
when I select "iris" it starts, is about a 1 inch square, I resize itt
o
about a 6 inch square, try to display a raster map, and get a "Error
setting map window" message. Once, I tried to select a file with
xgbrowser in d.rast and XGRASS crashed (leaving a segmentation fault
msg. in my console from which I had started it).
-Do you have the fifo's needed for "i0, etc" for the iris driver?
-Could you mail me your d.mon from xclip and your monitorcap files if
you have this working without hitches?
I would really be grateful!
* Good news: I did get SG3d running, and am indeed impressed. Thanks.
Thank you in advance. I saw sample output from xgdisplay on the GRASS page,
and am really looking forward to get it working. We don't have a printer, so
all of my printing has to be done to a ps file.
Sincerely,
Matt
Matthew T. Mellon
Department of Geology
University of Pennsylvania
Room 251 Hayden Hall
240 S. 33rd St.
Philadelphia, PA
19104-6316
mmellon@mail.sas.upenn.edu
