Juan
I have had similar problems. I am running SuSE 6.1 with kernel 2.2.7 on a
twin P2 400 SMP machine. the recommended compile seemed to work for me. I ran
configure and then make install. After successfully generating several object
files and doing some linking, the output was:
warning multiple common R(char, long double __restric, long long)
warning multiple common R__cury
warning multiple common V__
unidentified reference to __waddbytes
I hope that this helps pinpoint the problems so that we can both try again.
Jim
===== Original Message From "Juan I. Santisteban Navarro"
<juancho@eucmos.sim.ucm.es> =====
I'm trying to compile Grass 5.0 beta6 and I'm having some troubles.
First of all, I'm trying to do this in a AMD K6 with Linux RedHat 6.0
(kernel v 2.2.13)My troubles are:
when I try the new method of compilation
./configure
make install
nothing happens.Then I try the classical method (with GISGEN) and it seems to work until
I receive the message in the module d.3d (and others) that the symbol
__bsd_signal is undefined in the library libcurses.so.1.0.0 and the
compilation stops.I've tried to use libncurses instead of libcurses, but the I receive the
message "__waddbytes" is undefined in libncurses.I don't know if I need a newer version of these libs or it is something
related to the code.Thanks in advance
Santi
Dr. Juan I. Santisteban Navarro
Dpto. Estratigrafía/Instituto de Geología Económica
Fac. Ciencias Geológicas
Univ. Complutense de Madrid
28040-Madrid
SPAINPhone: +34 91 3944785
Fax: +34 91 3944808
e-mail: juancho@eucmos.sim.ucm.es
