Date sent: 14-JAN-1992 08:53:15
I am having trouble using the v.in.arc command. The error message
"cannot find ARC-INFO lines file" is displayed. I have tried
putting the lines and points files from the ARC 'ungenerate'
command in several different directories. Is there a specific
file naming convention for these files different than adding a
.lin and a .pts after the filename?Jim Klein 804-924-6438
Use the v.out.arc command and see where it creates the file,
I believe its in $MAPSET/arc . Try putting your "ungenerated"
files there.
Good luck;
Gerry Hatcher
Ocean Mapping Development Center| Gerry@omdc.gso.uri.edu {Internet}
University of Rhode Island |
(401)-792-6940 | cbeam::gerry {span}
