|I am reading a landsat tm imagery to unix, and using i.tape.tm command in
|grass3.0. But a error message pop up.
| ERROR reading tape: read 1536 chars, should be 1027158323
|How can I solve the problem?
i.tape.tm is expecting OLDer format tapes. If you are have the new
"fast" format tape, you will have to extraCt the data "by hand" using
"dd" and then r.support.
Michael
