region boundaries & G_get_map_row
if my region is: n=23 s=1 e=16 w=1 nsres=1 ewres=1,
should there be 21 or 22 rows in a raster file?
I'm having problems with s.sample related to G_get_map_row:
row = (int) G_northing_to_row (north, &window);
if (G_get_map_row (fd, maprow, row) < 0)
WARNING: [elev in PERMANENT] - read request for row 22 is outside region
DIAG: Region is: n=23 s=1 e=16 w=1
         Data point is north=1 east=4
There should be 22 rows,
STARTING WITH ROW 0 - so row #22 would be the 23rd row
The only way you should be getting row=22 is if
(window->north - north) / window->ns_res >= 22.0
which DOES happen when north = window->south - so it seems
that since points ON north are IN the region, then points ON
south are not. Otherwise, for two contiguous regions a point
on south of the north region would be in both regions.
The data point is at the southern boundary of the region. By my
definition, the data point (north,east) *is* contained within
the region. Is my definition wrong?
That's wrong.
(north, west) *is* in the region - the other corners belong to
other regions.
In other words:
In the program, I check to see if a site is contained within
the region using:
   if (sites[i]->east >= window.west &&
       sites[i]->east <= window.east &&
       sites[i]->north <= window.north &&
       sites[i]->north >= window.south)
Should this be changed from "<=" and ">=" to "<" and ">", respectively?
Or should I just change the comparisons for west and south?
I think this would be right:
         sites[i]->east < window.east &&
         sites[i]->north > window.south)
- Bill
