Mail*Link(r) SMTP gnuplot
Hello
I am haveing trouble installing gnuplot. I downloaded ver 3.5
from
ftp://ftp.dartmouth.edu/pub/gnuplot/gnuplot3.5.tar.Z
I then followed the instructions.
ln -s makefile.g Gmakefile
edit Gmakefile <-- nothing changed here
gmake4.1
From this I got an error as follows
babbler{joe}180: gmake4.1
SRC = /usr/local/src/grass4.1.5/src
CMD = /usr/local/src/grass4.1.5/src/CMD
HEADER = sparc5
ARCH = 5.4
GISBASE = /usr/local/grass4.1.5
VERSION = 4.1 Spring 1993 Update Package 5, January 1995
/usr/local/src/gnuplot/gnuplot
make -f OBJ.5.4/make.rules
gcc -g -o /usr/local/grass4.1.5/etc/bin/main/cmd/g.gnuplot OBJ.5.4/binary.o
OBJ.5.4/bitmap.o OBJ.5.4/command.o OBJ.5.4/contour.o OBJ.5.4/eval.o
OBJ.5.4/gnubin.o OBJ.5.4/graph3d.o OBJ.5.4/graphics.o OBJ.5.4/help.o
OBJ.5.4/internal.o OBJ.5.4/misc.o OBJ.5.4/parse.o OBJ.5.4/plot.o
OBJ.5.4/readline.o OBJ.5.4/scanner.o OBJ.5.4/setshow.o OBJ.5.4/specfun.o
OBJ.5.4/standard.o OBJ.5.4/term.o OBJ.5.4/util.o OBJ.5.4/version.o
/usr/local/src/grass4.1.5/src/libes/LIB.5.4/libdisplay.a
/usr/local/src/grass4.1.5/src/libes/LIB.5.4/libraster.a
/usr/local/src/grass4.1.5/src/libes/LIB.5.4/libgis.a -ltermlib -lm
Undefined first referenced
symbol in file
bzero OBJ.5.4/bitmap.o
bcopy OBJ.5.4/parse.o
getwd OBJ.5.4/command.o
ld: fatal: Symbol referencing errors. No output written to
make: *** [/usr/local/grass4.1.5/etc/bin/main/cmd/g.gnuplot] Error 1
This is the same header file I used to compile GRASS4.1.5 .The machine is
a SPARC 5 running SOLARIS 2.4.
The only thing that has change since the compilation of GRASS is
that I upgraded the gcc compiler from 2.5.6 to 2.7.2. This should
have no effect- should it!
I then applied the patche file enhpost.patches
and run gmake4.1 again. I got the same errors.
I would be gratefull for any HELP
joe
Joe.Leone@per.dwe.csiro.au
------------------ RFC822 Header Follows ------------------
Received: by qmgate_backup.anl.gov with SMTP;18 Dec 1995 08:40:07 -0600
Received: (from daemon@localhost) by diego.cecer.army.mil (8.7/8.7) id
DAA08150 for grassu-people; Mon, 18 Dec 1995 03:36:22 -0600 (CST)
Received: from max.cecer.army.mil (max.cecer.army.mil [129.229.20.254]) by
diego.cecer.army.mil (8.7/8.7) with SMTP id DAA08147 for
<grassu-list@diego.cecer.army.mil>; Mon, 18 Dec 1995 03:36:20 -0600 (CST)
Received: from babbler.per.dwe.CSIRO.AU (babbler.per.dwe.csiro.au
[192.245.212.100]) by max.cecer.army.mil (8.6.9/8.6.9) with ESMTP id DAA21672
for <grassu-list@max.cecer.army.mil>; Mon, 18 Dec 1995 03:15:13 -0600
Received: (from joe@localhost) by babbler.per.dwe.CSIRO.AU (8.6.10/8.6.9) id
RAA03657 for grassu-list@max.cecer.army.mil; Mon, 18 Dec 1995 17:33:05 +0800
Date: Mon, 18 Dec 1995 17:33:05 +0800
Message-Id: <199512180933.RAA03657@babbler.per.dwe.CSIRO.AU>
Sender: grass-lists-owner@moon.cecer.army.mil
Reply-To: grassu-list@moon.cecer.army.mil
Precedence: Bulk
Sender: grass-lists-owner@moon.cecer.army.mil.
Reply-To: grassu-list@moon.cecer.army.mil.
Precedence: Bulk
To: grassu-list@max.cecer.army.mil
Subject: gnuplot
X-Sun-Charset: US-ASCII
