'remote' monitors with XDRIVER?
Hi everybody
The current thread about twelve students using GRASS reminded me
of a problem we have: we run GRASS on a SUN (SunOS 4.x) and we would
like to use it remotely on other machines (e.g. HP).
GRASS itself is no problem - xterm works fine. However, we can't
open a monitor. Is there any way of passing a DISPLAY argument
to XDRIVER so the monitor window appears on the local machine?
Any pointers welcome (including hacks to the XDRIVER code)?
Martin
Martin Ameskamp, Inst. f. Informatik I (Computing Dept.)
Kiel University, Olshausenstr. 40, 24118 Kiel, Germany
Fax: ++49 431 8804054, Voice: ++49 431 8804474,
email: ma@informatik.uni-kiel.d400.de
I don't have a system set up where I can really test this properly, but I
would have thought that you could set the DISPLAY environment variable
before calling d.mon. You could put the variable assignment and the
d.mon-call in a subshell, say using shell parentheses. Let me know if that
doesn't work.
-- Mark
Mark P. Line Phone: +1-206-733-6040
Open Pathways Fax: +1-206-733-6040
P.O. Box F Email: markline@henson.cc.wwu.edu
Bellingham, WA 98227-0296
