John Parks writes:
To get a grass map to color PostScript, I can think if two ways...
both require that you have the ppm software (comes with grass)
compiled.(1) o Display the map in a GRASS X-Windows Display
o run: xwd | xwdtopnm | ppmtops -scale X > filename.ps (where X is
some value like .8 just small enough that ppmtops does not complain
about the image being too wide... trial and error)(2) o select the driver ppm in p.select (if you have it compiled) and
run p.map with your scale set to 8inches. Run the p.map script.
(This put a file paint.ppm in your home dir)
o run: ppmtops -scale .75 - > filename.ps
Just a side note: if your image is better printed in landscape mode, you can
rotate the ppm file 90 degrees before running ppmtops instead of sending
commands to the printer. An easy way to rotate the ppm is to insert
pnmflip -rotate90 | into the pipe stream between xwdtopnm and ppmtops as
described in (1), or to run pnmflip -r90 paint.ppm before running ppmtops
as described in (2). The ppm software works very well, from my experience.
Chris Murphy murphyc@cgrb.orst.edu
Dept. of Entomology, Oregon State University
Corvallis, Oregon USA
