RGB file created by NVIZ2.2
hi, all
i posted that nviz2.2 created a wrong RGB image file. i found that the header
was reverse byte order. so i fixed it at least on FreeBSD.
if you get a broken RGB file, check grass/src/libes/libimage/close.c and
change
#else
  if(image->dorev)
#endif
to
#else
  if(!image->dorev)
#endif
Best Regards,
Huidae Cho
