rim capability in Grass 4.21
I have twice installed Grass 4.21 under Linux (Slackware with kernel
version 2.0.30) according to to the excellent instructions from Markus
Neteler, and each time I have run into a small problem with the RIM
modules. I fail to correctly compile about halfway through the g's (i.e.
up to getloc.f) with successful output executables and then fail on a
file not found.
what file is missing? I could compile it successfully on my Slackware
box.
Perhaps you get the binaries, they should work.
Markus Neteler
