RIM Installation
This is a LINUX box. I can't get RIM to compile for anything. When I correct
the makefile and type
cc rim.o -o rim -lrim
I get a bunch of different errors, in the same line. It seems I am missing
some library or another. Help?
I did a successful "make librim.a", so librim.a exists and has been installed.
# make rim
(cd src; make rim)
make[1]: Entering directory `/map/new/src.related/rim/src'
cc rim.o -o rim
/usr/lib/crt0.o: Undefined symbol _main referenced from text segment
rim.o: Undefined symbol _rmcons_ referenced from text segment
rim.o: Undefined symbol _rminit_ referenced from text segment
rim.o: Undefined symbol _sysini_ referenced from text segment
rim.o: Undefined symbol _rmdate_ referenced from text segment
rim.o: Undefined symbol _rmtime_ referenced from text segment
rim.o: Undefined symbol _msg_ referenced from text segment
rim.o: Undefined symbol _s_cat referenced from text segment
rim.o: Undefined symbol _systrp_ referenced from text segment
rim.o: Undefined symbol _rimcmd_ referenced from text segment
rim.o: Undefined symbol _setout_ referenced from text segment
rim.o: Undefined symbol _dmsg_ referenced from text segment
rim.o: Undefined symbol _sysexi_ referenced from text segment
rim.o: Undefined symbol _exit_ referenced from text segment
make[1]: *** [rim] Error 1
make[1]: Leaving directory `/map/new/src.related/rim/src'
make: *** [rim] Error 1
# exit
Script done on Tue Sep 6 01:06:57 1994
rjones@halcyon.com net.viking OG+GOT;
GCS/S/O: d? H--- s+:+ g+ p1+ au-- a- w+++ v++ C++++ UL++++ P+ L++ 3- E---
N+
K++ W++ M-- V-- -po+ Y++ t !5 jx R G''' tv+ b+++ D++ B--- e+ u*--- h---- f
r+++ !n---- y++++ GeekCode v2.1 available: finger hayden@vax1.mankato.msus.edu
