RIM reply to John Miller: ccjwm@jcu.edu.au
   Use this file with the `.input' command immediately after you
start v.db.rim interactively (ie., `v.db.rim database_name'). Then read in
the desired vector map(s) with `.re filename attnum name'. You will
then be able to query by attribute # or by catagory names.
   (If anyone on the lists has worked on entering multiple text fields
into RIM without MANUALLY entering each new entry, I'd sure like to hear how
you did it!!)
    Ronald Thomas ^ ront@meeker.cfnr.colostate.edu
     Natural Resource Spec. (GIS) ^
      Resource Management Division ^ Phone: 303-586-3565 x285
       Rocky Mountain National Park ^ 700-323-7285 (FTS)
        Estes Park, CO 80517 ^
We managed to read multiple columns into RIM by using the Unix 'join' command
and by editing the header information of the ascii RIM files.
If you need more information, please contact me.
Carlo van de Rijt
Dept. of Ecology
Un. of Nijmegen
The Netherlands
