RISC Arch - signal processing
X-Sun-Data-Type: text
X-Sun-Data-Description: text
X-Sun-Data-Name: text
X-Sun-Charset: us-ascii
X-Sun-Content-Lines: 27
Run time error - XDRIVER ...SWITCHER.c
I have successfully compiled grass4.1(version 3 update)
on a RISC machine. XDRIVER compiles ok. But, when I run
d.mon and try to open a graphics window, I get the following error:
grass4.1> d.mon start=x0
longjmp or siglongjmp function used outside of saved context
bsh: 6005 Abort: A memory image file is created as "core".
Please start graphics monitor <x0>.
Error - Graphics monitor <x0> not running!
Problem selecting x0. Will try once more
grass4.1>
the signal processing is done in SWITCHER.c in .../XDRIVER/XDRIVER
The source code has been compiled and runs on a SUN operating system
without any difficulties.
I do not have much experience with signal processing and would appreciate
any input people may have.
Thank You
Daniel Epstein
X-Sun-Data-Type: default
X-Sun-Data-Description: default
X-Sun-Data-Name: err
X-Sun-Content-Lines: 7
aPlease start graphics monitor <x0>.
