"rotating" raster maps
I am importing some ascii files as rasters which need to be transformed
so that the rows become columns and columns become rows. I have examined
m.rot90 but this seems to work only with generic ascii files and not
GRASS raster maps.
First, uncompress the grass raster file with r.compress -u. Specify the number
of bytes per cell (found in the cellhd for the file). If the format is 0, then
it is 1 byte per cell (nbytes is format + 1). The input file must be placed in
a different mapset out of the present search path, and a new cellhd file needs
to be made which reflects the altered rows and columns (Don't forget to change
the region, too, to reflect the changes in rows/cols). Finally, mv the colr,
cell_misc, and cats files to the new file name. Both m.flip and m.rot90 work
this way. Compress the files when completed.
Rick Thompson- Research Assistant E-mail: rick@cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-5736
Ozark Hall Rm. 12 Fax: 575-3846
University of Arkansas
Fayetteville, AR 72701
