rotating rasterfiles?
Date: Tue, 8 Jun 93 20:13:25 EST
From: cerl!cerberus.earth.monash.edu.au!simon (Simon Cox)
Message-Id: <9306081013.AA19150@cerberus.earth.monash.edu.au>
I have some rasterfiles (imagery, sort of) which I am importing.
Unfortunately, some of these are rotated 90o. Can I rotate
these, within grass, prior to rectification, or should I
let i.rectify handle it? WIll it choke?
I cannot use m.rot90 as the files are already imported as grass raster layers.
SUggestions?
Simon COx simon@cerberus.earth.monash.edu.au
I believe that if you decompress your grass raster files, you can use
m.rot90 to rotate them. m.rot90 does not recognize them as grass files
so you need to provide the complete path name to the cell directory in
your mapset for both the input and output files. Also you will need to
rebuild the cellhd following the rotation and cp (or mv) to the new
rotated name any other support files you already have (colr, cell_misc, etc).
Hope this helps.
Susan Stitt
  National Park Service, Geographic Information Systems Division
  PO Box 25287 12795 W. Alameda Parkway
  Denver Colorado 80225-0287 Lakewood Colorado 80228
  (303) 969-2596 susan%nps@cerl.cecer.army.mil
