Running GRASS from a shell...
How do you run GRASS from a shell without going through the intial querying
at the beginning. In other words I just want to run the GRASS programs and
not enter the interactive mode. Thanks,
Sam Gustman tel - (603) 646-4711
Computer Engineer fax - (603) 646-4278
CRREL - Army Corps of Engineers email: samg@hanover-crrel.army.mil
72 Lyme Road Hanover, NH 03755 STC Contractor
Set the following environmental variables:
GISRC (should be your_home_dir_path/.grassrc)
GISBASE (where the bin, etc, and scripts directories are found)
GIS_LOCK (usually set to the process id of the start-up shell script; I would
use the pid of the current shell)
GISDBASE (the Database of the the query page)
LOCATION (the Database + the Location + the mapset)
MAPSET (just the Mapset name)
Add the following paths to your PATH:
$GISBASE/bin
$GISBASE/scripts
$GISBASE/garden/bin
IF I haven't overlooked anything, you should then be able to run GRASS programs
normally.
Malcolm D. Williamson - Research Assistant E-mail: malcolm@cast.uark.edu
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
