s.db.rim and RIM problem
  Please let me know if you hve used s.db.rim to open a database created in
RIM? The database was exported to a text file and then imported for use with
the
s.db.rim command. The imported database is listed as available; however, I
can't open it. The error message is RIM ERROR CODE #1: Unlisted Rim error
message.
   Thanks.
   Sharon Des Rosiers, Applications Systems Analyst
