s.in.ascii
I have imported into
GRASS a sites file that has eastings, northings, and an elevation value.
After running s.in.ascii there is also a pipe between each of these.
I would like to have a pound sign, "#", before the elevation value as well
(for use with s.menu option 6-convert site map to raster map where each
#n is a category value).
Questions:
Is there any way to add the # sign (some way that is not docmented or that
I have missed) while running s.in.ascii?
Is it possible to do it in the s.menu option 5-edit function?
I am not an awk or sed user, although I am now sitting down with the
books and beginning...
Thank you for your help
-Nancy
