s.in.ascii
Hello nancy,
If I understand your question, you have a file with
  x | y | z
in them and want
  x # y # z
try the command
  sed 's/|/#/g' infile > outfile
an explanation
  sed is the command
  the ' ' are to isolate the sed command from the shell
  s is the switch command
  /| is what to search for
  /# is what to replace with
  /g tells sed to replace all |'s found on each line not just
    the first one
  infile is you x | y | z file
  sed will write to standard output unless it is redirected
let me know if you have any questions
oops I just saw johnson's e-mail with a different approach
why awk when you can sed ???
