Hello Henk,
It sounds like you're missing a character before the z variable. I think
you need to add an # to all your z variables in the file you are reading
in with s.in.ascii. Therefore:
X Y Z
123 342 #23
All should then be ok.
Best regards,
Chris
Hi
I am struggling to get s.in.ascii to produce a site file that I can use
for interpolation. I can produce an ascii file containing x, y and a z
column. The z column contains a numerical value that will be used for
interpolation. So far, nothing has worked. I have tried prefixing the z
with a % and without. This puts 0's into the site list. interpolation
gives errors pertaining to invalid formats and no data found. I will be
good and tabulate all the attempts and problems, unless someone can
point me at information that will help me start from scratch again
Thanks
Henk
Henk Coetzee
Geophysics Unit
Council for Geoscience
Private Bag X112, Pretoria, 0001, South Africa
Tel: +27-12-841-1192 Fax: +27-12-841-1424
C.D.Lloyd
Department of Geography, Email: cdl195@soton.ac.uk
University of Southampton, Phone: +44 (0)1703 592205
Highfield, WWW: http://www.soton.ac.uk/~cdl195
Southampton,
SO17 1BJ,
England, UK
"C.D.Lloyd" wrote:
Hello Henk,
X Y Z
123 342 #23
This is what I thought as well. The resulting sites file then looks like
22:30:02.484E|27:59:59.136S|0|
s.surf.idw then says "I'm finding records that do not have floating
point attributes"
and stops, with the message:
"s.surf.idw: no data points found"
Henk
Best regards,
Chris
> Hi
> Thanks
> Henk
> Henk Coetzee
> Geophysics Unit
C.D.Lloyd
Southampton,
SO17 1BJ,
England, UK
Henk Coetzee
Geophysics Unit
At 02:37 PM 10/4/99 +0200, you wrote:
"C.D.Lloyd" wrote:
Hello Henk,
X Y Z
123 342 #23
point attributes"
use the management programs to edit the sites file and replace the
qualifier on each height i.e. make every "#" a "%" instead ( or put a "%"
in front of each height).
Henk
>"C.D.Lloyd" wrote:
>> Hello Henk,
>> X Y Z
>> 123 342 #23
Hi
I have done this and imported the file using grass4.2.1, which seems to
interpolate OK. Is this a problem in 5.0beta3?
Henk
Henk Coetzee
Geophysics Unit
