s.in.ascii
Hi Henk,
you need a preceding "#" character for the z-value.
To overcome the problem easily do following:
* In GRASS 4.2.1 use
   s.in.ascii.dem instead of s.in.ascii
* In GRASS 5 use
   s.in.ascii -e
This will add the required characters.
  Markus Neteler
Hi
I am struggling to get s.in.ascii to produce a site file that I can use
for interpolation. I can produce an ascii file containing x, y and a z
column. The z column contains a numerical value that will be used for
interpolation. So far, nothing has worked. I have tried prefixing the z
with a % and without. This puts 0's into the site list. interpolation
gives errors pertaining to invalid formats and no data found. I will be
good and tabulate all the attempts and problems, unless someone can
point me at information that will help me start from scratch again
Thanks
Henk
Henk Coetzee
Geophysics Unit
Council for Geoscience
Private Bag X112, Pretoria, 0001, South Africa
Tel: +27-12-841-1192 Fax: +27-12-841-1424
Markus Neteler wrote:
Hi Henk,
* In GRASS 5 use
   s.in.ascii -e
Thanks
This is what I have tried. I get a file with rows that look like:
23:19:51E|17:44:16.98S|%579
But s.surf.idw tells me "s.surf.idw: no data points found"
Henk
Henk Coetzee
Geophysics Unit
